slide240wayz »
https://forums.nicoclub.com/slide240wayz-u19320.html
Fri May 26, 2006 9:04 am
There are 4 allen screws you need to remove to remove the shield/ outer part of the BOV. The o-ring has to be in there as well. Make sure the c-ring is in there 100 percent. The allen screws can be reached from the front portion of the BOV. If you remove the wrong ones, the cover and the rubber piece will come off all together. You do not want to happen, make sure you pick the correct one ( every other)
