timmyk »
https://forums.nicoclub.com/timmyk-u130530.html
Wed Apr 01, 2009 5:36 am
It smells badly like fuel sometimes and I don't make power after 4,000 rpm.
I looked up the smelling like fuel problem and everyone suggested it could be fuel filter or injectors. I don't believe it is my filter cause it hasn't clogged up and stalled out....
However, I'm thinking it could be my injectors cause my friend though it was the o-rings on the injectors were leaking, causing me to loose fuel pressure.
Now, I have a set of stock ka24de injectors that I had in my 96 s14 ka24de, before I turbo'd it.
Could I take the orings off those injectors and put them on the SOHC injectors and would this fix my problem?
Or should I instead get a ka24de fuel rail as well to make the ka24de injectors work in the ka24e engine. And doesn't anyone know if these are the same flowing injectors? Because if there bigger, wouldn't that mean I'd need a tune to make them flow correctly?
