Boulethemerc wrote:It seems that the motor is f***ed or maybe just the wires are broken..how can i be sure that its a motor problem or just the wires?
the window is not responding when i push the window button, sometimes i can press the button and nothing happen..then when i close the door the window just go down..
i wanna be sure whats the problem before buying a motor,and then i go to the car shop and they told me that it was just a wire problem!:P
ill wait for ur answer..thanks in advance
Evidently for it to go down it must have went up.
I would look at the switch. If you are concerned about the motor, pick one up, you may well have to have the door apart anyway for the switch.
Perry
