Problem with my door
forsaken
Car: cars, music, pool
My interior light comes on when Im taking turns as if the door is being opened. Also on the highway today my light that shows that the door is open came on when I know it is shut. What could be causing it? Is it the latch or some sensor?
quiksilvia
Car: 95 s14 se
is it a hatch? my door open light comes on and off cuz the hatch sensor, i just turned off the interior light, cheap fix
HachiRoku
maybe your switches are bad/loose?
forsaken
Nope its a coupe and i did turn the dome light off, but i was hopeing that I could fix it.
quiksilvia
Car: 95 s14 se
check the sensors and wiring, good luck
SloS13
I super-glued a nickel to the inside of my door so it acts like a shim cuz my door ajar sensor sux..
Car was in an accident, so door is funky
quiksilvia
Car: 95 s14 se
on a scale of 1 to ghetto, thats up there with eating stolen fried chicken on ur porch with an ak47 on ur lap
SloS13
you should see the rest of the car :D
forsaken
rofl!!! I'll check it friday morning. hopefully its something simple, because while nothing big it sure is annoying!
wiwalsh
Car: school, and my 240!
Does it matter which way you are turning? Right turn it will be your left door, left turn its your right door. If it does it turning both directions, switch is probably loose or bad wiring.
With the car sitting still and one door open at a time, try to push each sensor in to get the light to go off, then wiggle the sensor back and forth, ovbiously if this re-creates the effect, repace the sensor...
Scott
forsaken
I know its the driver door...
wiwalsh
forsaken wrote:I know its the driver door...
slick... then visit a junk yard, pop that bad boy replacement sensor in, and you should be good to go....
ballr858
try tightening down both screws on the striker. my dome light used to come on and off on the freeway and on turns too. after tightening down the striker, it stopped.
forsaken
cool thanks for the tip I'll try that when i get my car back with the swap :)
