TS240sx »
https://forums.nicoclub.com/ts240sx-u10197.html
Sat Oct 04, 2003 2:50 pm
I bought this 95 240sx 5 speed for 2200 with 175K on it, everything is in good shape except a few problems, here are some problems i have.
1. engine clicking/ticking when the car is idle, valve or fan bearing?2. rough idle, idle is normal after your start the car, it jumps a little if you turn your steering wheel between 400~900(is this normal?). also after you run for a while, when you stop the car, rpm jumps again around 400~900. after jumping for like 5 second, it stops around 600 and stays there.3.when i crusing , everything seem fine, but when i go over 3000 rpm, rpm jumps a LOT, jump between 2500~7000, just jump like crazy, but the weird thing is i dont feel any difference in the engine, sometimes needles goes back to where it suppose to be for awhile and starts jumping again......4. when i am driving, if i step on the clutch, RPM goes down to to 100 or 200 sometimes almost zero, but car doesnt stall, and if i shift to netural, it stays around 600 and not moving....
can someone please help me with this RPM problem......thanx a lot
