RatedR »
https://forums.nicoclub.com/ratedr-u4104.html
Wed Jul 21, 2004 7:07 pm
Try unplugging the ground on the clutch pedal. Should be somewhere behind the pedal, but on the clutch bracket. Then put a jumper, or any conductor, to keep the circuit closed. You could have a bad line from that to the ground. That'd be the first thing I'd check....
