mattd1979 »
https://forums.nicoclub.com/mattd1979-u21551.html
Sat Jun 28, 2008 7:11 pm
I would but I am using a dial up connection and it would take time to get them up. I believe I figured it out. I got the switch and a volt meter, set it to ohms and I put one probe on the first pin with the letter "c" that I belive stands for common (ground) and set the switch on 0 and put the second probe on each of the other pins and found that they were all open, so I set it to 1 and put the probe on the second pin which was now closed but the other 3 pins were open, so I continued by selecting 2 and then 3 which when selected the 2 and 3 pin would ohm 000. I didn't go past 2 which would be level 3. I ended up straight wiring the wire that would be on the 3rd pin which was green to the wire that was not insulated which was connected to the first pin "c". The funny thing is that unless I manually shift the engine, it will not pass 7,000 on the tach before it shifts. Before I straight wired it and the switch was still connected, when I would have it set to level 3, the engine would always race past 7,000 (to 7,300) when I would leave it in drive and now it shifts right at 7 if not before.
