problem with keyless entry
Want to talk about non-Nissan cars? Here's the place!
angeleyes90
Car: nissan mirca se 5BR
My keyless fob was accidentally put in the laundry the other night and the red LED light on the fob was flashing it let me lock/unlock the car by the buttons on fob but not on door handle. So i left it for a day and today changed the battery and the car isn't locked which i'm worried about. But anyways i tried fob after changing battery and still won't work. I tried reprogramming it and tell me if this is the wrong way to do but taking the key in and out of the ignition 6 times? Let me know if it's wrong and there's another way. Or do you think i should get someone out as it's not flashing up green on dashboard and won't let me start the car.
Thanks
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
First, :welcome:
I'm sorry, but it's entirely possible your key fob may have been damaged in the wash. Your best bet would be to go to your local Nissan dealership and have them check it for you.
angeleyes90
ok thanks i do have a spare key also, do you think i should try program that
Rogue One
2022 Honda Pilot SE
angeleyes90 wrote:ok thanks i do have a spare key also, do you think i should try program that
I'm inclined to say no. I did find this online, but whether it will work is uncertain.
Technical Information supplied by Nissan Car Key Specialists AutoKey Squad.
Ensure all the doors have been unlocked, either by using a good transponder key or remote
control plip key.
Procedure:
1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds.
2. Next, turn ignition switch to OFF position. Leave key in ignition switch.
3. Wait 2 seconds then the system will enter programming mode and will flash the warning
lights twice.
4. Press and HOLD the unlock button on the Plip.
5. While pressing the unlock button, press the lock button 3 times.
6. Release the unlock button.
7. The warning lights will flash once to indicate successful programming.
8. Repeat procedure 4 to 7 for up to 4 plip key’s.
9. When completed turn ignition ON, and the warning lights will flash 2 times.
10. Remove key, and check all plip key’s for operation.
NOTE : The programming mode will stop when either the ignition is switch ON, 4 plip keys
have been programmed or no input signal either from the switch or plip keys has been received
for 120 seconds.
AutoKey Squad hopes this advice solved your car key problem.
maxxoo77
Hi, Welcome to this Forum Site Here u can find lots of members Related to ur problem ,
I suggested u for this question you have to ask to the experts , i dont know about this problem
Top Ten classified websites *Weblink redacted* :nono:
Reason: Remove unapproved content
Return to “Others”
