lelek240sx »
https://forums.nicoclub.com/lelek240sx-u37932.html
Fri Mar 03, 2006 2:48 am
hi , not too long ago i got 95 ecu tunned by jwt to work on my 98 s14and since than i cant get my car to run right . it started when i first installed this ecu , car would idle very lean 18-1 19-1 . after spending couple hours i find out that crankcase breather needs to be rec back in to the intake , that helped a lot for idle but the car still drives bad . i get between 14,3 - 14,6 at crusing speed wich is a little rich and 9.8 to 10.1 - 1 at wot wich is super rich , plus sometimes car will go to under 10 -1 at normal city driving for couple seconds than back to 14,7 or it would go lean (17.1 -1) for couple of secnds and than back . it really pisses me off especialy if im driving in traffic and car will shoot flames really loud without even without boosting . im going to try to move maf 18 inch from turbo , now is about 8 inches , plus im going to try different tps because one i have is a litle low at wot ( .32v idle 3.4 wot ) my settup is 95 jmt ecu 5 speed 740cc injectors z 32 maf 8.8 to 1 arias pistons bov rec back in to intake please tell me what you guys think thanx
