Hi All,
I am having a problem with my heater and wanted some advice on how I might be able to fix it. The fan and air conditioning work fine. When I am driving on the expressway with the heat on I can feel hot air coming out of the vents as expected. Perhaps even warmer then I would expect. However, if I am sitting idle or stopped at a light, the system will just blow cool air. Which I suspect is how cold it is outside
Any advice or ideas?
Thanks
