Problem with halo headlights in Versa. Help!!!!
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
marshallpeterd
Car: 2007 Nissan Versa
The headlight on my versa is the halo kind. i just changed it 2 days ago. it look really great but the turn signals doesnt work. i cant figure out what is wrong with it. Please anybody who has answer on this please reply. Thanks!!!
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
did you try changing the bulbs?
marshallpeterd
I havent tried that yet. thanks for the info. but if it still didnt work what do you think is the problem?
superskunk
if you replace the bulbs and still nothing then i would check your fuses.... and if still nothing then i would try your stock headlights.... and if the problem still persists than i would contact the seller and ask them for a new set... good luck
Urq
Car: 82 Ur Quattro & 07 Black Versa SL CVT.
My first thing would be I would check voltage at the light before i started just replacing bulbs?
Return to “Versa Technical Discussions”
