problem with gauges,headlights, tailights......
ziptek
Car: 300zx
ok the car runs fine and all but when i turn on my headlights they only stay in high beam. I got no low beams, and my gauges wont turn on either and neither will my break lights?? what could it be? help plz!!? :confused: :wtf2:
robomatic12
Car: 1990 300ZX TT
ziptek wrote:ok the car runs fine and all but when i turn on my headlights they only stay in high beam. I got no low beams, and my gauges wont turn on either and neither will my break lights?? what could it be? help plz!!? :confused: :wtf2:
Have you checked all fuses? The battery is ok? It could be the headlight switch gone bad, check for power and diagnose with the online 300zx serice manual (google it).
ziptek
Car: 300zx
ok i'll give all of that a look lol...I'll let you know what i find thanks robomatic12
ziptek
Car: 300zx
ok robomatic12 it was a fuse, everything works now thanks again. :dblthumb: :biggrin:
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
ziptek wrote: ok robomatic12 it was a fuse, everything works now thanks again. :dblthumb: :biggrin:
Clearance Illumination fuse by the clutch pedal?
ziptek
Car: 300zx
Clearance Illumination fuse by the clutch pedal?[/quote]
yes, i believe so
Halient
Car: Various Z32's
SC300 - yes its a 2jz :D
ziptek wrote:Clearance Illumination fuse by the clutch pedal?
yes, i believe so[/quote]
Was this in the box or under the dead pedal?
BigTDogg (MA)
Halient wrote: Was this in the box or under the dead pedal?
Look at clutch, look left, there is a panel that slides up to reveal fuses. IIRC, it's on the top row.
