joe603 »
https://forums.nicoclub.com/joe603-u34652.html
Mon Apr 30, 2007 3:49 am
Provided that you put the clutch pedal to the floor each time, the 3 most likely culprits are:
1. Ignition switch2. Electrical problem (battery, switches/relays)3. Starter/solenoid
It's probably the ignition switch, but I have seen cars do weird things...check the easy things first-battery terminals/connections; make sure they're clean. Check the ground terminal off the negative...make sure it's free from corrosion as well.
I'm not convinced it's the clutch switch. Usually when they go, they go completely...not intermittent.
