I have been having this issue for quite some bit and to try and troubleshoot it ive done the follow...
-sprayed starter fluid into the intake to make sure i have spark and it was a fuel issue (started right up no problem when i sprayed in the fluid)
-moved the fuel pumps ground point from the the rusty fuel pump cover to bare-metal part of the chasis.
-pumped air through the fuel lines to get all the gunk out (cars been sitting for a while) and there was nasty black stuff in there...
-tested the fuel pump with a small battery to make sure it works... and it does.
-replaced the fuel filter for a brand new one.
-replaced the fuel pump fuse
-quadruple checked the fuel pump connects from the rb25 ecu to the s13 wire.
and im getting nothing. what im thinking it is, is something with the fuel pump? because i can NOT hear it prime when i turn the key to ON.
any help is appreciated!
