drjohn »
https://forums.nicoclub.com/drjohn-u115.html
Sat Aug 03, 2002 1:05 pm
There is a fan resistor in the blower motor box. It burns out and the lower speeds go through the resistor and high bypasses it. You will need to replace the resistor and the fan motor. The fan is drawing to much current and burning out the resistor. If your mechanicely inclined you might be able to disassemble the motor, clean up the brush contact area on the armuture, lube the bushings with 3-in- 1 oil and you might not have to replace the fan motor.
