Problem With electrical HELP PLEASE!!!
latnluver425
Car: infiniti Q45
Thanks for checking my topic. Well i have a problem with my electrical i would assume. My sun roof was open one night and got into the wires under the center console so now my dash board light where all the guages went out and my break lights went out to so when i press on the break only the middle lights comes thats on the window. I turn on my head lights and the lights in the back dont come on. please help and tell me what it could be thank you!!!
DrewQ45
Car: 1990 Infiniti Q45
latnluver425 wrote:Thanks for checking my topic. Well i have a problem with my electrical i would assume. My sun roof was open one night and got into the wires under the center console so now my dash board light where all the guages went out and my break lights went out to so when i press on the break only the middle lights comes thats on the window. I turn on my head lights and the lights in the back dont come on. please help and tell me what it could be thank you!!!
Your post leaves a lot to the imagination. I assume you you have a Q45 and that water got in the electronics. I suggest you check all your fuses first. Pull the fusebox cover which is on the driver's side near the parking brake release. Pull your fuses and check to make sure none are blown.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Yeah theres no way of knowing..... I wouldnt think that the palce where the sunroof could get water on stuff would effect anything like that.....
chinaonnitrous
Car: 2002 Maxima to 2004 Evoloution to 1992 Integra
Let it dry for a few days. Check all fuses, and try again.
goody90q45
Car: 1992 Infiniti Q45 (sold)
I agree. Air it out. We got a lot of rain and wind in NorCal over the holidays. I was in Santa Cruz parked for a few days near some eucaliptus trees. My car looked like it had been in a battle zone.
If you've got a 90-96 Q it's pretty easy to remove all the trim components around and below the shifter to let things air out. You can speed up the drying by leaving a shop lamp on in the car overnight. Don't put it too close to anything that could melt, and keep what your trying to dry out around 90-100 degrees. Wouldn't hurt to also unclip any harness connectors you can see while the lamp is on as one or more of them may be wet on the inside.
Don't feel bad, you're not the first person to post in this forum about a rain drenched center console.
