BigDankCloud »
https://forums.nicoclub.com/bigdankcloud-u104182.html
Fri Sep 12, 2008 7:18 am
Issue with the pro kit is that I'm getting slight knock sounds. The strut master is tightened down as best as it can be (i tightened it again after the car was put back down to the ground as suggested). I'm trying to find out if others have had the same problem, or maybe get some suggestions on what to diagnose. Everything is as tight as its going to be without ripping out threads from things or rounding out/ shearing off bolt heads.
I can turn the wheel, and hear a slight pop on both sides of the car (they don't always happen simultaneously, but turn the wheel enough and you will hear the pop). it is not loud, and looking under the hood i see no wear around bolt heads. Could it be the control arm somehow?
I'll take pictures and post them up here later if needed.
Thanks,
Dank
