mtcookson wrote:The IACV must be connected to the intake after the MAF. Otherwise, it will suck in un-metered air causing it to run lean. Its basically like having a huge vacuum leak. Hook that back up and it should run perfect.
There are actually CAI kits for older Honda Accords (90-93 I think) that work perfectly on the VG Maxima's. Those are the most popular way to go for VG intakes. The two piece style like this is the one that works:
http://cgi.ebay.com/ebaymotors...25667
Definitely get a different air filter. The K&N's are terrible to have on cars with a MAF. The oil from the filter will get on the wire and will cause issues.
THANK YOU!!!
It makes sense now...at first I was just dumbfounded and didn't know what to do.
As for the intakes...I wish I would have seen that earlier but oh well I already have the stuff on there. I will however get rid of the K&N. I'll let my brother put it on is Eclipse or I'll just sell it. What filter do you recommend of the top of your head??
I was thinking of just getting an AEM dry one but if you know of one better I'd like to know.
But thanks again man...very glad you chimed in!!!
