NismoDriver240 »
https://forums.nicoclub.com/nismodriver240-u85415.html
Tue Aug 05, 2008 5:51 am
same exact prob happened to me...
go under the car and on the transmission you'll see the slave cylinder, it looks like this...
check to make sure the rubber boot isnt leaking, mine was and the pressure was lost in the lines so it wont come back, idk how much it cost for labor to fix it since I just swapped my motor, but the part is only $40.
If that doesnt do it then it might be the master cyliner. Thats this part:
It's under the hood in the top right corner. Make sure that has fluid in it to the correct level.
To fix it yourself just replace the parts and bleed the clutch by pouring fluid (DOT Brake Fluid) into the master cylinder reservoir and pumping the shyt out of the clutch pedal to get the fluid to fill the lines. Once pressure starts to come back you'll feel more resistance on the pedal and then it will come back to life.
Alos, you can do this, it'll cut the bleed time to nearly nothing, but if you do be wicked careful:
http://garage.projectraine.com....html
good luck and welcome to nico
