Problem with clutch cylinder and throw-out bearing fork, help?
StuntingShaggy
Car: 1991 240sx
Ok i'm editing this post due to my own atrocious lack of common sense. I go the clutch cylinder in but now there's no pressure to my pedal...probably because my clutch reservoir is down to the minimum level...
Modified by StuntingShaggy at 11:48 PM 1/16/2007
MagikDragon
Car: 1991 240SX, 1992 240SX, 1986 MB 190E 2.3-16
you are going to need to bleed the system. it should be pretty easy w/ a couple of friends.
nissanman04
Car: '90 240SX, '95 Subaru Legacy
bypass the damper box while ur at it. it'll make bleeding go MUCH faster.
