WBS »
https://forums.nicoclub.com/wbs-u47898.html
Wed Sep 27, 2006 4:28 pm
I have a 1999 G20t. About 2 years ago, the automatic door locks started operating erratically when I tried to use the remote control. Sometimes the locks failed to respond to the remote. After a while, unlocking the doors using the remote became almost impossible. Locking usually takes several tries with the remote, but is not as difficult as unlocking. However, I can always get it to work manually using the key. I've noticed that this typically happens when the car has been parked for a while. If I've been successful using the remote after several attempts, it will work correctly the first time if I immediately try it again. I started using the spare remote that came with the car but the same thing happened. The Infiniti dealership cleaned and checked the remote and verified that it was working properly. It seemed to be a little better at first, but unfortunately, the same problem returned within a few days. Has anyone had this same problem?
Thanks.
