b_vanfossen »
https://forums.nicoclub.com/b-vanfossen-u79516.html
Wed Mar 11, 2009 11:14 am
My ashtray will not close. I removed the assembly and found out why- which is unrelated to my problem I'm asking help with...
The problem is- There is a not so small black spring that puts tension on the ashtray when closed so when you press it- it springs out.
For the life of me I cannot see where this spring goes- do any of you know how it attaches?
When the center wood panel is removed- the ashtray comes out because it is attached. If any of you happen to have yours out I believe you can look through the bottom to see where this spring sits. I believe it rides on a small brass colored shaft that the ashtray pivots on, but cannot see where on the shaft it sits and where the metal prongs rest.
thanks for your help!!Brian
Modified by b_vanfossen at 4:59 PM 3/11/2009
