SkylineDriven »
https://forums.nicoclub.com/skylinedriven-u8874.html
Mon Dec 15, 2003 12:06 pm
Last night I was driving and as i was braking to a stop, the car's dash lights dimmed then stalled. I restarted the car... and continued driving. It didnt stall again but occassionally that night, the dash lights started dimming again as the rpm's dropped down to the 500rpm mark and started acting like it was going to stall (ths only happens when braking to a stop) and sat there for a while, then jumped back up to normal idle (while stopped).
What is the deal... I have new 02 sensor, plugs should be in good shape cuz they were replaced when I bought the car 5k miles ago, along with wires, cap, and rotor... what else could of caused this problem. I had a milder form of this problem before but it went away after I replaced the o2 sensor. The only thing different is new fog lights... but I have been running with the fogs for a while and I don't think its cuz of bad grounding since they are directly wired into the parking lights.
Possible alternator going bad? Or some other type of mechanical failure? The belts are new as well. I got a free 27point inspection not too long ago so I don't think that I have vacuum leaks or anything. Anyone have ideas? If worse comes to worse I can take it to a mechanic to diagnose.
