Problem with Alignment!
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
alik
Car: 2007 G35 Sport
I have an 07 G35 Sport.My car is only 3 months old with 3500 miles on it. Ever since day one, my alignment was off. Note this: The car doesn’t pull left of right, it drives perfectly, but when the steering wheel is centered, the car pulls to the right. I’ve been to the dealership 4 times. They checked everything (oh so they say), no damage to tires or wheels, no frame damage nothing. It’s a brand new car. Every time they do my alignment, it gets worse and worse. Finally the answer that I got from them is that this is how it supposed to be.
Anybody had a problem with the steering wheel not being centered? If so how did you fix it?
Thank you
abdoman
Car: 2006 G35
I had the same issue with another car. Take the car to a tire shop as even brand new tires can have problems. Have them check the tires. You could have a tread separating or collapsing.
alik
Car: 2007 G35 Sport
hmmmmmmmmmmmmmthanks ill check thatbut in any case, if its the problem with the tires, the dealer shold cover it.
abdoman
Car: 2006 G35
Yes, unless the tire was damaged. If you hit a pothole or something in the road, you could be paying for a new tire or two.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Sounds like to me they didn't center the steering wheel during the alignment. The car is probably driving straight and the steering wheel is cocked to the left a few degrees. When you try to drive with the steering wheel straight, obviously the car is going to pull right.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
