Slo_240sx wrote:Its bouncing because of a bad connection. When you pulled on the wire you probably pulled the pin out al little bit of the ECU. When you tapped the wire did you solder it in? Do it and tape it/shrink wrap it.-Alex
Thanks for the reply.
But, I didn't pull the pin out of the ECU a little. It is still intact.
I tried 2 different ways to tap into the tach line. First, I removed some of the sheething to the tach wire and solderless connected the shiftlight to the tach wire. That produced the formentioned results.
I then tried a second approach by soldering it to the tach wire. That produced the same results as well. But, the second I remove the shiftlight from the tach wire, the tach on the instrument cluster will work just fine. It only does this when the shiftlight is attached to the tach wire.
