areznik »
https://forums.nicoclub.com/areznik-u13487.html
Fri Feb 20, 2009 12:07 pm
Guys,
My Q45 '94 is at about 165K now, holding strong. My low beam passanger headlight stopped working (high beam is fine). I thought must be the bulb and without thinking twice bought a new one. After replacing the bulb the low beam still does not work. I checked the voltage between the three pins and it goes only to 4.5v as opposed to the working low beam on the driver's side that goes up to 12v when on. This puzzled me quiet a bit (did a basic check for fuses that are located just above the passanger headlight, and all seem to be fine).
What could happen that it does not get enought voltage at low beam??
Thanks,Andre.
