problem with 370cc injectors
Rusty 240
Car: 2x s13
this week-end I was trying to put my 370cc injectors and the cover over the injector was not sitting on the fuel rail as usual, like the old ones. I was wondering if it happen to someone else or someone can help me on this one. thanks
virus77
Car: 95 S14, 71 240z, 97 e320
did you give it a good amount of force with proper lubrication , no seriously they dont pop in too easy maybe that was the problem.
skatanic28
Car: 96 240sx
yeah mine took a decent amount of force to get onto the rail too.all 4 of mine "popped" as they got seated right.
PapaSmurf2k3
Site Admin
yeah i had to beat mine in there with a hammer and a block of wood. food for thought.
Structure240sx
you might want to becareful when doing something like this.
the screws that hodl those injector caps down only require slightly more than 1 ftlbs of torque. i only finger tighten the screws now. very lightly turning the screw driver with a loose grip til my fingers slide off.
i used to tighten them all the way down nd had problems for a week of tearing up the lower o-rings.
tighten them gently and start the car. if fuel leaks tighten them more. if fuel doesnt leak take it for a WOT ride check for leaks and tighten if necessary
Rusty 240
Car: 2x s13
thanks I'll try your suggestions soon as possible
GEO
Car: 95 240sx KA-T
yeh wot it and have it leak... boom
