Cold_Zero »
https://forums.nicoclub.com/cold-zero-u2277.html
Fri Feb 13, 2009 3:48 am
Lots of good information here. I would have to say that if it pulls to one side, you probably have an alignment problem. After you have done what EZCheese and SteveTheTech have suggested, get under your car and inspect the suspension, if everything checks out visually, take it in to the shop and have the alignment checked. A change in wheel size/tire size may through off the alignment if the wheel/tire specs on the 18's dont match your OEM wheel specs or especially if you hit a monster pothole.
Just to share with you, my wife's car had aftermarket wheels and she experienced catastrophic failure
I guess my view on fixing wheels is that since wheels are tires are what actually connect your car to the road, I wouldn't chance it. But that is just my opinion.
