dr-rjp »
https://forums.nicoclub.com/dr-rjp-u48968.html
Thu Nov 09, 2006 9:43 am
OK...enough cornball.
First off, a little background:
I put a set of KYB AGX's on my 1998 I30. I still have 15" wheels on it (but with 215/60 x 15 tires). Keep that in mind as I tell my tale:
Overall I like the AGX's, but, they are causing havoc with my neck injury...which is why I am contemplating selling them.
HOWEVER, that is not the problem I wish to discuss here. The problem has to do with handling on wet roads.
While the AGX's have vastly improved my handling on dry roads, on wet roads, they sometimes cause my rear tires to lose traction in turns, and that causes the leading front tire to briefly skid sideways.
The tires, BTW, are nearly new, Fuzion HR-i, and they have been simply fantastic in wet weather. Well, they were when I still had the stock struts & shocks. Then, I switched over to the AGX's.
Without knowing all the details as to why wet handling has changed, I tend to feel that the stock 15" tires are a part of the skidding problem because of how the handling dynamics have changed.
When my car had the stock struts & shocks, it would lean (a lot) into turns, but that lean could actually be beneficial in a way if that extra weight kept both the front and rear tires firmly planted to the asphalt. Of course, the extra weight on one side increases momentum and centrifugal force on that side and the tendency for the FWD car to plow into the turn is increased.
Now, with the AGX's, although the body lean is greatly minimized because of their stiffness, the car now seems to tilt as a whole to where the rear tires lose some traction on left-hand turns.
I do not know what is actually taking place, so forgive me if I tell you what it feels like:
It feels as if the car is being lifted up...as if the centrifugal force is pulling up on the car because the centripital force is pulling down on the car -- there is about 180lbs of driver sitting on the left side of the car and adding to that downward force.
If someone were to take a photo of my car from behind, I'd bet I see one of my rear tires up in the air.
OK, my question is "How do I counteract that effect?" (besides going on a diet or having a fat friend sit in the passenger seat).
Would a rear sway bar help?
Would larger diameter tires help?
Would slowing down help? (of course, it would, but me? Slow down?)
Thanks for your help.
