Bronze MFP »
https://forums.nicoclub.com/bronze-mfp-u7726.html
Thu Nov 17, 2005 2:33 pm
It sounds normal. If your tires don't grip enough to reach the diff's breakaway torque, then it will stay locked and act like a welded diff, making your tires hop a little. You may be able to adjust the breakaway torque, but i think you do that by adding or taking away plates inside the diff itself, not by adjusting a screw anywhere. I used the stock shims in my diff too, that's more for aligning the ring and pinion gear and would not affect the performance of the diff itself.The way the 2-way clutch diff works, it will lock on accel or decel. because a cam inside the diff is pressing on the plates, thus locking them and keeping your wheels spinning at the same speed. when you are not on the gas, or have the clutch pressed in the cam is not forced against the plates, the diff doesnt lock, and you get no noise/commotion going around corners.
Check out the illustrations in this PDF file, it should help you understand why your diff does what it does.
