just because its pressure while cranking dosent mean its enough while running. an engine cranks at less than half the speed of when its idling.apex_7 wrote:It's not the CAS, I barrowed one from a friend and it does the same thing. It's not the fuel filter b/c I've got fuel pressure while cranking. I should be getting my injectors back soon and I'll check the injector plugs w/ a negative test-light.
yeah, its a guy local to us but he will work with shipping them as well, he ships to australia fairly often. http://www.deatschwerks.comEikon wrote:hey apex_7....
can I ask where you sent your injectors to have them checked out? Is it someplace local to you? I have an extra set of RB20 injectors that I can send out to have flow tested and cleaned, but I am not sure where to take them and what to expect cost to be.
thanks
