Problem w/ Brake Light?? HELP PLEASE
General discussion area for the L32-chassis Altima
altimusprime83
Car: 2008 Blk Nissan Alt.
Hello,
I was curious I know that its almost time for my brakes to be changed, since I took the wheel off and checked them. Yet
Have you ever seen the Brake Light highlight on the dash, due to this??
I was worried maybe it was something else??? Any help please
malnevets
Car: 07 Altima Majestic Blue
if you have the brake light on, check that your E-Brake is not engaged.
it is possible you accidently pressed down on it a little bit while getting in/out of your car
Lyon
Car: 2007 Nissan Altima 2.5
altimusprime83 wrote:Hello,
The brake light will also come on if the brake fluid is low. FYI
bhs07c
Car: 2007 Nissan Altima 2.5S
Same thing happened to me. In my case, the light would blink on while I was gunnin' it or riding high RPMS. It's probably not your brakes though..just your fluid level. Every shop I've ever taken my car into has mentioned that the 4th gen altimas have a tendancy to run low on brake fluid. No biggie.
Return to “4th Generation Altima Sedan (2007-2012)”
