USDM_OneVia »
https://forums.nicoclub.com/usdm-onevia-u6319.html
Sat Mar 20, 2004 8:42 pm
Well..... driving home a couple of days ago in the beater (the 91 fastback) I went to come to a stop off the highway. I reached down for the clutch pedal and it was gone! I am like WTF?? So I reached down with my hand and it is stuck to the floor. No big deal I thought... just a messed up Clutch Master Cylinder, just 24 bucks at autozone and a 30 minute fix. Easy right.... WRONG!!!
I get the car towed home and I finally get to work on it today. I put in the new clutch master cylinder and then go up underneath the car to modify the hardline to bypass the stock damper box. There is no way I am going to spend 3 hours bleeding a clutch when you can bypass that stupid box and have it done in 2 minutes. While looking at the slave cylinder I noticed it was kinda ****ed to one side. It wasn't pointing straight onto the clutch fork, it was kinda pointing towards me on the passengers side. I figure, just unbolt it, and then bolt it back up correctly. So I unbolted it and it immediately grenaded in my hand. Springs, pistons, lever arms, and clutch fluid are all laying in my hands. So I run up to Advance Auto again and become 18 dollars poorer. I get back, bolt on the new one. But then I notice the clutch fork is not lined up to the slave cylinder and there is a TON of play in it. I kinda had an idea on what had happend and I was preparing for the worse. I took the dust boot off and looked inside the transmission and my fears were confirmed.
Not only was the clutch fork no longer on the pivot bolt, the damn pivot bolt had sheared off inside of the clutch fork. I mean it is sheared CLEAN off. Crap! I am finally starting to get some parts together so I can park the coupe (CA18DET powered) and get all my go fast parts on it while still having the beater to drive around and now I have to focus on the beater and get it running again.
Here is my question. Which is the easier route to fixing the bolt? Pulling the whole motor/transmission combo or just dropping the transmission. I work in my garage and space is very limited and I usually work alone on my cars, so which route would you guys go?
I hate bone stock beaters that prevent you from working on your projects.....
Joe
