problem
infinitiI30
Car: infiniti I 30 1997
my climate control, defrost, and hazzard button do not light up, could this be cause of a blown fuse? if so, does anyone know which fuse would need to be replaced?
MetaOrbit
Car: Black 2002 Infiniti I35 Sport
infinitiI30 wrote:my climate control, defrost, and hazzard button do not light up, could this be cause of a blown fuse? if so, does anyone know which fuse would need to be replaced?
...Could be a fuse...why don't you check the fusebox to see which fuses are blown?
infinitiI30
MetaOrbit wrote:...Could be a fuse...why don't you check the fusebox to see which fuses are blown?
how do i go about doing this?
PoorManQ45
like I said in your tire thread, go on over to the Infiniti General section. They will help you ouut alot
Rex
Car: None
Fuse panel should be near your left knee, the cover should pull off somewhat easily and be labeled as to which fuses are for what. It should also have a fuse puller and a couple spare fuses in it.
That should be enogh to start, check back.
Mr1der
I love Infiniti owners
check the owners manual and it should have a diagram for the fusebox and tell what each fuse does. Find the one for uh...I guess interior lights or instrument panel or something along those lines and pull it out and see if the metal inside has burned through.
oh, lay off the dope too it's bad for your reflexes mang!
