Problem!!
kapower
Car: 1993 Nissan 240sx
alright i have a 93 nissan 240sx. lastnight my car decided to die on me on the way home. i have no idea what is wrong with it. it turns over, but doesn't start up. today i got some new wires and a fuel filter thinkin that was the problem cause it was time for the tune up and filter change. well, that didn't work. i checked the fuel pump and it was priming when needed. i made sure i had spark, and everything seems fine. i also checked the fuses all they were fine too. Now, a couple of weeks ago, my intake fell and the MAFs plug landed on the powersteering pulley and it burned all the insulation off of it, down to the bare wire. i wrapped each wire in electricly tape and it ran fine until now. i have no idea what it could be. i am thinkin i need a new plug, or maybe an injector. what do you think??
InsanityInc
does the starter crank? If it just died suddenly, it's probably something pretty serious... or it could be the battery... did you check that?
kapower
yeah the starter is kicking in and all. the battery is fine cause all the power is on. i am thinkin it is MAFS, cause right before it died it started to run really rich
