Ubernoober »
https://forums.nicoclub.com/ubernoober-u14357.html
Thu Jul 14, 2005 5:14 pm
Hmm. Lots of suggestions, but I guess nothing has gotten better.
We'll start with what I actually know and then I'll go on to guess later.
First, the black box that has a line running up to the air filter box isn't the EGR. It is actually designed to let air into the exaust to help complete combustion of any unburnt hydrocarbons running through the cat. It is controlled by a vacuum motor and a set of reed valves. This system can go dirty allowing exaust into the intake. This will certainly caus eproblems with fuel metering. Many people remove this, but the simplest fix is to pull the line off the vacuum motor and plug it. If the vacuum motor never opens, there cannot be any flow in either direction.
Second, it looks like you have tried really hard to focus on the MAF which is good since the symptoms support that, but it may be time to use that "known good" MAF and move on down the line.Any unmetered air getting into the intake will cause a lean condition. Check your gaskets and vacuum lines.Pull and plug the vacuum line off the EGR vacuum motor (at the back of the intake manifold). Aslo, make sure your EGR valve is working correctly. If it isn't closing that can be a major problem.
Se if that makes any difference and we'll go from there.
