problem
trinitys-14
Car: s-14 97'
I have 240sx 97. Everything seems to run fine, except my car shakes a lot.when I mean shake it rattles a lot when I go over 60m/h and when I put my gear into reverse. I dont think i has anything to do with alignment or tire pressure, because I have already checked it out many times. I think its a bigger problem like loose motor mount or something.
Does anyone have similar problem as me? Or have idea to how I could fix this problem. Please leave me some input.
p.s. extra info: I have over 100k/m in my car right now.
tony/ka24de
I have a shaking problem to. Mine only happens at certian speeds and when i let off the gas i shakes at certain speeds.
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Mine vibrated around 50 MPH because I needed a new driveshaft carrier bearing, and had to get the driveshaft balanced.
troll's 240sx
It probably have something to do with your driveshaft and carrier or the balance on your tires. Maybe a bent rim also.
Ubernoober
Find out if it is speed related or RPM related. That will tell you whether it is engine or drivetrain. Then continue to eliminate from there.
trinitys-14
Car: s-14 97'
I believe it is speed related... b/c rpm stays pretty low when I hit 60m/h.
