slidecrave »
https://forums.nicoclub.com/slidecrave-u47700.html
Tue Mar 27, 2007 10:55 am
I posted this in the online Mechanic area but i figured since its a CA might as post it here to see if anyone has experienced similar problems.
alright first i just wanna ask if anyone has heard of using a tractor battery in a 240.. cause i just got this coupe and the previous owner was using one although the battery doesnt seem to be the problem just curious if anyone has done this?
now the problem i'm having is that i go to start the car, key in everything turns on just fine seat belt goes back then i try to turn the car on and everything just dims out like it lost power and the engine hasnt even moved a bit no crank or anything. So i checked all the fuses, none of them are burned out and i checked that button around the clutch pedal and click it in and no difference. So then i get a friend to try to jump my car and no difference there either. Ao i dont really know what it can be.. Anyone have any ideas what i should try?
a CA has been swapped into it but i got that all running and starting up and drove it around a couple times before this problem happen so idk.. On the other hand there was some engine start button that the kid before me had wired up. Which i didnt know what it did until i started messing with it and pushed in the clutch and it started my engine once, but then later on when i went to try it again the next day it didnt start and was when the problems started so idk if maybe it has something to due with it or not.. maybe the ecu got fried..?
i know its long but i dont know what else to try.. thanks guys
