gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Sat Nov 10, 2007 10:17 am
When you turn the key, do you hear a click coming from the general area of the starter?Remove the starter and have it checked at a parts store. It may be the solenoid giving out.Also, check the connections for both tightness and corrosion build-up. Power, earth at the battery and starter, check applicable fuses, you know the drill.Check the clutch interlock switch. Basically unplug it and jump the connector with a piece of wire.Lastly you may need to have the ignition switch itself checked out if all else fails. This is actually the order in which my starting problems have evolved. My new switch will be in tommorow morning. ($36 at Advance Auto)
