rocksteady_racer »
https://forums.nicoclub.com/rocksteady-racer-u29694.html
Sun Dec 18, 2011 10:29 pm
I have a 90 240sx with the stock ka24e. It was starting fine a couple of days ago. I swapped my 300zx brakes in the front. Now I can't get it to start at all.
When I crank it, it cranks strong and fine. It's been rich for a while and the EGR is stuck in place which I think is part of the rich problem. But it was running well enough to drive before. Now I went to start it the other day to check my brakes. It wouldn't crank over unless I held the gas all the way down. Then it started but only revved to 2000 rpm and as soon as you let off the gas pedal it would slam flat on it's face off.
Today I tried to start it after cleaning and replacing the IACV and it won't start at all (also it's freezing outside not helping it any).
I have an aeromotive FPR and it's reading the proper fuel pressure from the pump so I know the pump is working. I keep hearing an odd buzzing noise randomly (not steady) under the hood (really loud with the hood open). It's grounded properly and the ignition is direct wired so I think it has got to be something to do with the IACV or one of the relays but I'm not positive. Any suggestions?
I'm going to go through all my sensors tomorrow to make sure they're all working. Anything specific that would cause these symptoms? I've searched but I get too many different answers to pin point my problem and most don't start ever with a buzzing attached. Thanks in advance.
