evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Jun 06, 2008 6:05 am
I'm a bit confused here, a mechanic took off a part taht was clogging causing the problem? but offerend not long term solution? assuming it's a clogging fuel filter it's likely due to rus in the tnak, if this si the case you can buy a replacement or have yours cleaned and sealed, or even buy a cleaning sealing kit form eastwood or similar, this help at all?
