Pillman9mm »
https://forums.nicoclub.com/pillman9mm-u124817.html
Tue Dec 08, 2009 5:20 pm
Ok update. This morning I took the car to Autozone and had them run their diagnostics on it. The dude said he got fine readings from the alternator and the starter but not good from the battery. So therefore, I opted to replace the battery with a Duralast Gold 100. I drove it home, sat for 30-45 min. or so and drove to work. At work it sat for about 6 hours in upper 20's/low 30's weather. When I went to start it, at first it once again would not. After about 5 minutes of trying, it started. Then after sitting for about 3 hours tonight in snowy weather, it took me 10 minutes to start. The lights aren't dim, the wipers, windows and heat work fine. Due to the issue I've not been running the radio. Now, one thing I do not know if comes into play. When I picked up the car originally, the Service Engine Soon light was on. The dealer ran it to a mechanic that stated this was due to an O2 sensor which was replaced. (I purchased the car in Feb. last year, so still winter) that light stayed off for about 3 months, then came back on and has been on ever since. Changing the battery today did not effect it, it's still on. Could this have anything to do with the current issue?
