I am setting up my turbo on my KA24DE s14
All the physical parts are installed properly and double checked; however, I'm not so good at the electrical wiring portion of the process. I looked up how to install the Z32 MAF Sensor and wired it up as I was supposed to, connected the ENTHALPY tuned ECU and it ran fine for 2 minutes. But after then the car began to bugging and shutting off. It would not rev up more than 1500 RPMS. When I disconnected the MAF, the car idled normally but would not rev past 3000 RPMs. Apparently something went wrong and now my car does not turn on at all, so I plugged in the stock ECU and it would turn on but run like total crap.
I do have a Apexi S-AFC II but it is not connected to my harness. I have looked up the schematics on how to wire it to the harness but I don't have a PDF reader on this computer, I will check later. I hope it tells me exactly how to wire it, or if anyone on this forum has better input on the matter, please help!!!!
Anyone with input on my whole situation, please help with suggestions or things I might be missing.
If anyone out here in Queens, New York or in the Tri State area can help personally, I would really appreciate it. Appreciation can be money if need be.
Thanks guys!
