onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Sun Aug 14, 2005 5:05 pm
Ok, first things first. 89 240sx auto.
1) I can't find the idle adjust screw on the passenger side by the intake manifold, can someone tell me where it is exactly, or even better take a picture?
Currently, I'm looking at the throttle body from the passenger side of the vehicle and don't really see an adjustment screw.
2) My problem is worse because I had an Unorthodox Underdrive Pulley installed. I believe there are marks, but I have no clue if they are lined up correctly - doubt it, I had this done a little while back by a mechanic & didn't think of making them set it tdc, etc.
- How am I suppose to set timing now? I just want to be able to set it to the 15 degree thing first.
Can I set timing by hooking up an Apex'i multichecker & not have to use a timing light?
- unplug tps- start car- have one person look @ multichecker- other person rotates the distributor until desired timing is reached- plug tps back in
I'm guessing the best way would be to set top dead center:- take out spark plug #1- turn the pulley clockwise until the piston is showing
remove the pulley- take out belts- then what? I'm not sure exactly the method to get to this pulley, I have electric fans, so it "shouldn't" be as bad.
put pulley back on w/ the correct mark lined up to tdc. Hopefully my UR pulley does have the correct marks.
I'd really prefer not to have to do this way.
