Problem removing alternator.
jackmode9316
Car: 1989 240 sx
Okay so the threads on my alternator are stripped (The threads that the tensioner bolt thing goes in to) The problem is that I cannot get my alternator off due to the slip ring being stuck and not allowing the alternator off of the main mounting. Even with all bolts removed. Here is a picture of the slip ring im referring to
Can anyone tell me how to get this thing unstuck? I tried wedging it out with the bolt and no success. ANy help would be greatly appreciated. I would hate to take this to a shop for something so simple. P.S. you guys are awesome.Thanks!
12Ounce
Car: 1993 Nissan Pickup KA24E
I think I know what you're going through. I recently gave up on removing an alternator from the bracket (after main bolt was removed) while everything was still attached to motor. Had to remove bracket with alternator to work bench and then whacked the bracket away from alternator.
Used a flat file to creat a bit more clearance on bracket before reassembling.
Is the slip ring supposed to be removable? Duh!
jackmode9316
Car: 1989 240 sx
No I dont think its supposed to come off... Im just trying to get the damn alternator off of the car! If i could do that, It wouldnt be much to get the threads re-tapped or at most a new alternator. I see what you mean. Remove the actual Piece that mounts to the Engine? I didn't even look to see if I could get it off. Damn that may just save me a couple hundred bucks.
Modified by jackmode9316 at 11:01 PM 2/14/2007
jackmode9316
Car: 1989 240 sx
12Ounce
After removing the belt, rotate the alternator far away from engine ... then the bracket mounting bolts are accessable.
jackmode9316
Car: 1989 240 sx
Im going to try and do that this weekend, privided its not negative degrees outside. Do I attack the bracket bolts from the top of the engine bay or from underneath the car?
Modified by jackmode9316 at 1:48 PM 2/15/2007
180fan
Car: 89 fastback
bracket bolts are through the bracket on the inside (where the alternator blocks hence why 12ounce gave you a very good suggestion of rotating the alternator up so you can gain access to those bolts holding the bracket in place).
jackmode9316
Car: 1989 240 sx
So I guess that means that I attack the bracker bolt from above the engine? As opposed to from beneith the car.
Modified by jackmode9316 at 12:22 PM 2/16/2007
180fan
Car: 89 fastback
probably easier from the bottom with your alternator being held up with a bungee cord
12Ounce
I don't really remember if I had to go underneath or not. I was doing an engine overhaul ... so a lot was going on.
Pat Hollett
Car: 1989 240SX
tapping the alternator ears will eventually move the alternator off of the mount. use a long punch and hammer or plastic hammer if you can get it in there. that sleeve usually slides out with the alternator.
SAINTJ
Car: Infiniti Q45T/A
I have a 94 Q45 and i have all the bolts out from the Alternator.but i can not get the Alternator out and i can not get the 3 bolts loose off the Alternator can you guys give me some help on what to do? [email protected]
