problem puting engine back in car please help
scheffler
Car: 92 240 KA-T
92 300zx TT
97 Tahoe
ok i pulled my motor out cause i threw a rod and got new morot in and but it gose in the trany except for like 1/2" pushed on forever couldn't get it inhas anyine had this problem or have an idea
Modified by scheffler at 10:08 AM 3/24/2005
Modified by scheffler at 10:11 AM 3/24/2005
slipnfall
Car: '06 D40
So you're saying the transmission spline is lined up, but the engine won't butt against the bell housing? Couple things:
Line up/bolt the transmission up to the engine before resting on the motor mounts. It's easier to maneuver the engine/transmission with the hoist, rather than just the transmission with the engine stationary.
Look around the edge of the bellhousing/block. There are 1/2" long, 1/2" diameter hollow 'pins', that are used to keep everything lined up. Make sure you don't have two in the same location(meaning, one in the block, and one in the transmission at the same spot). This happened to me, my machine shop must have taken it out, and just installed it wherever they liked.
Once you're sure of that, line up the baffle plate(the thin piece of metal that goes inbetween), with a screwdriver/bolt. After that, put at least 2-3 bolts in spread out, just start their threads in. Tighten them each up little by little, and the two will pull together.
In my experiance you don't need to worry if it's 1/2" or closer apart. As long as you can get everything to line up, the bolts will do the rest of the work.
Lastly, the motor mounts are adjustable, so don't beat yourself up trying to get them to line up in their original place.
HTH,-Slip
DAEDALUS
Car: 1990 Infiniti Q45
Very good advice.
slipnfall wrote:In my experiance you don't need to worry if it's 1/2" or closer apart. As long as you can get everything to line up, the bolts will do the rest of the work.
The bolts develop a LOT of tension, so make sure nothing is binding (like the pins or teeth mentioned). Sometimes torquing them up is too easy, and if you're not paying attention you could break the housing. Castings are brittle and can have weak spots.
hondahunter180
Car: 2003 audi a4 - 1969 bmw 2002 - 1990 s13 (sold)
try twisting the spline little by little, also is your clutch aligned correctly?
scheffler
Car: 92 240 KA-T
92 300zx TT
97 Tahoe
thanksjust wasnt sure and din't want to force any thing
my89240sx
Car: 89 240sx
have someone push the clutch in, it will snug right up
Henry G
Yeah, it sounds like all you need to do is tighten the bolts down. Let us know how it goes..
scheffler
Car: 92 240 KA-T
92 300zx TT
97 Tahoe
ok i got it in when i went back to shop next day it just slid in in like ten min really easy any way thanks for the advice got bolts in and engine runs good thanks
