metalsyth »
https://forums.nicoclub.com/metalsyth-u14802.html
Mon Nov 15, 2004 5:55 am
I got it to free up the pressure plate must have just been a little wider and it was hanging on the bellhousing cause the motor to hang up.
Now that is fixed I have a severe overheating problem. New thermostat and radiator hoses, I know the fan clutch is bad, ran water through radiator and it didn't seem stopped up, the fan shroud was off and don't know if the water pump is bad. Also when the truck was overheating the radiator was hot on one side and cold on the other. It was overheating while driving it around with no hood on also.
Do you know where I can find a diagram on the vacuum hoses?
Any idea or help will be most appreciated.
