APCdude »
https://forums.nicoclub.com/apcdude-u14161.html
Sat Mar 27, 2004 10:27 pm
So my stock s13 has the rattle problem(loud, metal rattling from around idle to 1500 or so RPMs. After some searching on the forums, many many people have reported the same, stating that it could be worn guides and/or a loose chain, and that it's probably best to replace or remove those pieces.
Recently my car began to spring a small oil leak. After a brief, but throrough examination of the undercarriage it appears that my oil pan is covered in an oil 'sweat' where there is a thin layer of oil around the pan itself, and parts in about a half-foot radius around the oil pan are coated in oil. Searching on the forums tell me that it could be that the gasket in the oil pan is worn or that the rear main seal of the engine has gone bad.
It seems, however, that these two problems could be related. Further researching on the forums indicate that people have had the bad rattle that I'm having, and use a detergent type oil and then switch to synthetic of a grade of around 15w-40 or so. (FYI- I use nonsynthetic 10w-30 Penzoil, although I've heard that isn't too good... also I live in Austin, TX and summer is approaching (90-100 F a day)) I heard of the oil called Mobil1 Delvac, and looked it up and it appeared to be quite impressive.
Anyway, my question is:Has anybody had the same problem that I'm having, an oil leak and a rattling sound from the front of the valve cover, and used cleaner/delvac and then switched to synthetic or semi-synthetic, and had it fix itself?The reason I ask is because I've heard mixed responses of cleaning and then switching to synthetic based, heavier oils and their effect on a stock system with very high mileage (approximately 145K).
All answers and opinions are greatly appreciated.
