Problem: No Fuel, Pump isn't Turning On, Tested line = 12V for 5 sec. on Acc.
AeonTorpor
Car: 1991 Nissan 240SX SE
1991 Nissan 240SX SE Fastback 2.4L 5-Speed
I was reading through a bunch of different search results and found that the black wire into the fuel pump is the power line. So I Jammed my good old multimeter + into the sucker and held the other to a clean bolt while my brother turned the ignition to accessory.
Results were 12V dead on.
I'm guessing this means the fuel pump relay is working and 12V = good fuse.
Now all this being said, I have just swapped out my 91 engine (blown) for a 92 (both KA24DE) and my pump was working perfectly fine before the swap, that's how I got home even after I spun a bearing.
Has my pump gone bad or is there something that I'm missing?
Edit: Posted in wrong forum, sorry.
Modified by AeonTorpor at 12:04 AM 8/17/2009
AeonTorpor
Come on, guys, really?
AeonTorpor
I replaced the fuel pump, problem solved.
Modified by AeonTorpor at 10:39 PM 9/11/2009
