affirmative...the car shakes a lot when idling. i have pulled the plugs after running the motor for a short while, but not of them are wet. i would expect one to be almost soaking wet based on the amount of gas coming out of the exhaust, but none are that way. just a lot of carbon build up on a couple of them and they are fairly new plugs.
what bushing is this under the fuel rail?
thanks!
MYFREE95,240SX wrote:did you try replacing the lower bushings under the fuel rail when you put in the new injectors? i just had the same issue in my 95 after doing the injectors the smoke is unburned fuel thats why it smells run it for a min and then pull your plugs and that will tell you which are not sealed properly the plug should be wet. i pulled mine and pushed it back in and after the fuel in the exhaust burned off it was fine. took like a 5 min ride till it all burned off. does your car shake alot when idling? are they the right injectors? lemme know whats up.
